Originally posted by unknown
A cheap solution, to a non-existent problem
Brian, it's on the carb festys ONLY (not on the ATX or EFI cars).
he's fitting a sensor to an ATX radiator because that's all you can get anymore, manual rads havn't been made in 15 years.Trees aren't kind to me...
Thanks! That makes a little more sense. From everything I've heard, the carb'd Festys almost sound more complicated than the EFI models.Brian
Use a little rubber hose on the other side to fill and cap it with, that will
leave plenty of room for expansion, it should tighten up kind of like a radiator
hose. Get hard when hot. Yes it will delay the switch just a little but not much.Reflex paint by Langeman...Lifted...Tow Rig
