brake rotors
  • brake rotors
    a little confused as to the removal procedure, manual says tie rod end has to be removed but i dont see that its necessary, an i missing something ????
    He said a bad word :nono:
    1990 Festiva
    1987 F-250 diesel-powered
    1984 Ironhead Chopper
    1999 Ducati Monster
    Tie rods don't need to come off, not sure why it would say that but I never had to when I still had stock brakes lol
      thanx
      didnt think so either
      1990 Festiva
      1999 Ducati Monster
        Maybe because they want you to take the knuckle off, press the hub out and unbolt the rotor?
        91GL BP/F3A with boost
          ^^thats possible
            well thats what the book says , but my replacement is a one piece assembly, not 2 like whats on it now
            1990 Festiva
            1999 Ducati Monster
              Take some pictures if you can so we can understand what you mean. From the sounds of you the 2 units are the hub and rotor. So you need to remove the entire hub unit, and then press the hub off of the rotor. After that you bolt the new rotor onto the hub. I have taken apart the rotor using a sledge hammer, but not advised....
                Do you have a Festiva or Aspire? The rotor replacement procedures are quite different between the two. Festiva rotors are "captive" which means that the hub has to be disassembled in order to replace them. Aspire rotors are mounted from the front of the hub so all you have to do in that case is remove the brake caliper and a couple of screws.
                Ian
                  Festiva
                  1990 Festiva
                  1999 Ducati Monster
                    here are some photos of a front wheels rebuild
                    Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
                      Originally posted by stonemaster View Post
                      Festiva
                      Then yes, the knuckles will have to be removed. The bearings are pressed in and they have to be split to get to the bolts that hold the rotors on.
                      91 Festiva GL "Scrat"
                      82 Honda Goldwing GL1100i
                      85 BMW 535is "Brunhild"
                        nuh uhhh!!!! i done did it on the car onced, and i do it to Accords all the time!
                          Using an on car lathe sure saves some work.
                            you ever get one to work on a Festy?
                              from the diagram it looks like the rotor/hub are bolted together, they slide onto the splined shaft and are held on by the halfshaft nut correct ???
                              BTW my replacement rotor/hub is on assembly and not bolted together
                              1990 Festiva
                              1999 Ducati Monster
