can anyone help me out here and maybee tell me why my dome light dont come on when i open up my driver door. it does on my passenger side... i took out that little switch on the bottom and replaced it with two others from my parts car, and still nothing... any ideas?
just a minor nuisence
Try spraying the switch with WD-40 or electrical contact cleaner? If you have a volt meter or test light you can check if the wire is live.Last edited by WmWatt; 03-16-2012, 10:20 PM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
that switch is a ground switch, it needs to have a clean contact to the chassis to make it workTrees aren't kind to me...
Yeap. Just worked for mine. Unscrewed the two screws. Scraped around body and reconnected. Works like a charm.Originally posted by FestYboy View Postthat switch is a ground switch, it needs to have a clean contact to the chassis to make it work
89 Festiva. carby. needs repairs!!
Open the door and look at the bottom rear of the door opening in theOriginally posted by caprisecca View Postcan anyone help me out here and maybee tell me why my dome light dont come on when i open up my driver door. it does on my passenger side... i took out that little switch on the bottom and replaced it with two others from my parts car, and still nothing... any ideas?
car. Back where most of you are this probably rusts and makes a bad electrical
connection.Reflex paint by Langeman...Lifted...Tow Rig
I give the light a good smack, Probably not your problem but the way those bulbs sit in they can bounce weird and get a poor contact surface.Owner of:
1991 Red Festiva L, 5 speed (Swagger Wagon)
In progress:
BP+G25MR swap, Kia rio axles hopefully.
