Originally posted by Bert
1990 Festiva Fuel Gauge bad Sending Unit
Correct me if I'm wrong, but isn't the access cover actually "below" the rear seat bottom on the left side, isn't it?88L - 'Twistiva' - 'The Fusion of Man and Machine'
93L - 'Vextiva' - Airport Car
Just out of curiosity, what did they want to charge you for fixing these fuel sending units?Originally posted by the_feist_in_festiva View PostI found someone in New York who rebuilds sending units. And I've found a bunch of other homemade fuel sending unit repair methods here and there. So I guess I'll do more research on it. But the gallon gas tank in the back sounds good too. I don't know anymore.88L - 'Twistiva' - 'The Fusion of Man and Machine'
Phone Bob's Speedometer up and ask.
Probably too expensive. I would give serious consideration to buying a used one from Germany.Last edited by bravekozak; 05-09-2014, 06:20 AM.
Yes.. Have to undo 4 bolts , remove seats, lift carpet, remove 4 phillipshead screws, under there is the Grail.Originally posted by Twistiva View PostCorrect me if I'm wrong, but isn't the access cover actually "below" the rear seat bottom on the left side, isn't it?
Sent from the depths of hell.Ford Festiva 1991 WA Model (5 Door)
Nicknamed the car 'The Chiva' (Chilli Festiva)
Avg Economy:
Highway - 7.32L/100km
City - yet to be determined.
Has anyone ordered one of these Fourgreen sending units? Does it fit and function as a direct replacement? If so, I'm definitely ordering one!1990 Festiva - Throttle Body/Manual Transmission
Bought in 2003 with 65k, now 219k
1988 Festiva - Carb/Manual Transmission
Bought in 2015 with 150k
Ask me in a month or so. I've got new carpet that I'm installing when my seats are re-upholstered. No better time to put the new FourGreen fuel sending unit in than when I've got the carpet torn out. I will say that carb'd fuel tanks have an "oval" hole where the fuel sending unit mounts ("oval" like your typical 1/4 mile high school track with straight sides and rounded ends) and the FourGreen fuel sending unit I bought has a mounting lid/deck that is more circular/not so oval-shaped. Both the tank hole and the FourGreen fuel sending unit lid have 8 screw holes in the same general pattern but I don't know for sure yet if the 8-hole geometry lines up perfectly. Even if they do, the gasket has to seat properly. We shall see....Originally posted by jrclark32 View PostHas anyone ordered one of these Fourgreen sending units? Does it fit and function as a direct replacement? If so, I'm definitely ordering one!Last edited by Twistiva; 11-26-2014, 04:05 PM.88L - 'Twistiva' - 'The Fusion of Man and Machine'
I went ahead and ordered one today... Part number QKK13760960. I'll let you know how it goes.1990 Festiva - Throttle Body/Manual Transmission
