Is this tiny little bypass hose on the corner of my cylinder head just simple quarter inch gas line ? I cant seem to locate a actual part number and mine started to leak today hit me up with the skinny guys thanks
Bypass hose
Mine rotted and leaked on my 91. It was a molded curved factory piece so i had to use a longer reinforced fuel line piece to keep it from kinking. If i had the original on my festy i would just go ahead and change it out now and avoid future probs on the road somewhere. JUst spent $17 for a gal of antifreeze.Last edited by denguy; 06-01-2012, 06:07 AM.
If the parts store will let you go back to where they keep the rad hoses and such you can usually find a 5/16 coolant hose with a ~90* bend in it that can be cut to fit. I don't have any part numbers for ya, but I've done that before. Lately I've just been scavenging a handful of hoses with the proper bend from newer ('05+) cars that I find in JYs. That way I have a stock of hoses that aren't 20 years old
No festiva for me ATM...
If you do mess up the original steel tube, you can drill and tap the hole to accept a barbed fitting with pipe threads on the end. Just drill, tap, and install the fitting and your back in business.Originally posted by iceracerdude View Postit's coolant line... 1/4"-5/16" ish.
Hopefully replacing the line will do it, the steel tubes do rot away, and the hose barb coming out of the head can just pull out if you're careless with it.You gonna race that thing?
The bypass hose is readily available at the McParts stores; they will be a bit long, for a variety of applications, so you just cut to fit. If possible, take the old one to match the diameter.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I'm willing to put money on it that it is... Mine on the carby engine was dry rotted like that too. If I end up using it on my BP I'm going to have to replace it too.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
Bp doesn't have it-Greg
Redneck Engineer
FOTY - '09
This comes up a lot. Gates hose part # 18206 is a good replacement. A bit longer. Cut to fit.'89L 110k mi. BP/G swapped
'90LX 68k mi. wrecked 12/14 RIP
'90 F250 4X4 108K mi.
'13 Kia Rio 5 LX 70k mi.
'18 Kia Soul 40k mi. Daily
'64 Studebaker Gran Turismo Hawk
'66 International Harvester pickup
