will that work???
help please!?!!??
http://www.fordfestiva.com/forums/sh...ad.php?t=38279 If your plastic is broken you might have to get another at a JY.
Those little circuit breakers are cheaper than the fuses and come with their
own plastic mount, at least the ones with the little bolts to attach the wires do.
You would need enough wire ends for all the wires plus 4 more to make
jumpers to connect the hot side of the circuit breakers. Make sure you do
solid crimps as this can be a high amp circuit. All cheap clean brand new stuff!!Reflex paint by Langeman...Lifted...Tow Rig
check voltage everywhere, at starter, at altenator, at battery, at ignition, etc...;
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
