Do I need an inner tie rod tool to replace the inner on a 93 stock festy? I was wondering if I could just get a wrench on there.
inner tie rod replacement
I've done it with just a wrench. It's a PITA, if you can get a crow's foot and some extensions life will be substantially easier for ya.1989 Carby L: Stock. Slow.
1998 Mustang Cobra: ported heads, cams, longtubes, 4.30 gears
2016 Focus ST: daily driven go-kart
Wrench. And I found out the hard way you have to turn the steering wheel all the way to one side (depending on which side you're doing) to see the pinhole. Then drive the pin out with something small. Wrench the inner tie rod off, and install the new one with red Loc-tite.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
