inner tie rod replacement
  • inner tie rod replacement
    Do I need an inner tie rod tool to replace the inner on a 93 stock festy? I was wondering if I could just get a wrench on there.
    I've done it with just a wrench. It's a PITA, if you can get a crow's foot and some extensions life will be substantially easier for ya.
    1989 Carby L: Stock. Slow.
    1998 Mustang Cobra: ported heads, cams, longtubes, 4.30 gears
    2016 Focus ST: daily driven go-kart
      Great big open end wrench (can't remember which one, 23 mm?) worked for me. Turn the steering wheel to find the most accessible way to get in there.
        I couldn't even find an inner-tie rod tool that fits, so yea I used a wrench also. It's really not that bad.
        #33 Ford Festiva "We Are Not Really From Iran" - 24-Hours of LeMons 3x Trophy Winner & Class B Winner
          Cool, thanks folks. I will tackle it this weekend.
            Wrench. And I found out the hard way you have to turn the steering wheel all the way to one side (depending on which side you're doing) to see the pinhole. Then drive the pin out with something small. Wrench the inner tie rod off, and install the new one with red Loc-tite.
                Thanks. I will do exactly that.
