Funny thing... I called my brother-in-law I got the car from, and he said that wasn't the stock gear, it had been replaced when he had broken the tab off of it, trying to get it out! Ha! It's all good. I'm hitting up the junkyard today or tomorrow, and I have the GPS in there for now.
Speedometer driven gear removal - HELP!
Http://www.Youtube.com/TheresGabe
1991 Festiva L Red: Daily Driver
1990 Festiva L White: R.I.P.
1988 Festiva L Silver: R.I.P.
1991 Festiva L Red B6T: R.I.P.
1989 Festiva L White: R.I.P.
1995 Aspire 2-door White: R.I.P.
1995 Aspire 4-door Red: R.I.P.
Originally posted by rickbz28 View PostDo you have an Automatic or 5-speed? I know 5-speed gears are the same as I have a Festy 5-speed in one of my Aspires and I am using the Aspire gear.I thought the Autos while different than the 5-speed were also the same.
Summary: Festy speedo gear MTX compatible with Aspire MTX
Festy speedo gear ATX compatible with Festy MTX
Therefore Festy speedo gear ATX and MTX interchangeable with Aspire MTX.
I'd be very interested in hearing comments about tooth counts of Festy gears VS Aspire. May be an opportunity to sync speedos while you're doing an Aspire brake and wheel swap.
ATX Aspire gear from a 97 4 door is blue and has 21 teeth.
Aspire MTX gear is white with 21 teeth and measures 3 5/16 inches from bottom of retaining flange to end of gear and the gear is 1 inch in diameter.The Festy MTX gear I have is an exact twin of the MTX Aspire gear.I don't know about ATX Aspire gear as I have never had one out to look at.
Originally posted by rickbz28 View PostAspire MTX gear is white with 21 teeth and measures 3 5/16 inches from bottom of retaining flange to end of gear and the gear is 1 inch in diameter.The Festy MTX gear I have is an exact twin of the MTX Aspire gear.I don't know about ATX Aspire gear as I have never had one out to look at.
replaced the one I broke with one from a '96 Aspire MTX (Fitting since that is what my engine is out of)... EXACTLY the same.
