LOL, pretty sure. When I put it on and it acted funny, but still ran, I switched them for S&G's. Didn't run at all. Uh, pic in a second.
B6 Swap Bogging down.
Yellow pointer for pressure line.
Beamed to you from an insane asylum in orbit around Saturn via Tapatalk.
Well, that came out tiny.Last edited by scitzz; 09-11-2012, 12:33 AM.Contact me for information about Festiva Madness!
just making sure... sometimes its the simple stuff, ya know?
if it's not sussed out by madness, i plan on being there early so i could stop by and lend a hand...Last edited by FestYboy; 09-11-2012, 12:42 AM.Trees aren't kind to me...
Exactly why I posted the pic! I might have messed up!Originally posted by FestYboy View Postjust making sure... sometimes its the simple stuff, ya know?
Dude! I am NOT used to being this stumped!
Jay suggested partially clogged baskets in the injectors, so I am going to take them out and try the B3 ones.Contact me for information about Festiva Madness!
If it isn't sussed out by Madness I may be truly insane by then! But thanks, and if I have to, I will take you up on it!Originally posted by FestYboy View Postif it's not sussed out by madness, i plan on being there early so i could stop by and lend a hand...Contact me for information about Festiva Madness!
Well I will be a cockeyed baboon. I pulled the fuel line, and no, I had that arrow to the wrong line. But anyway, I hooked it up just like the B3, but no matter. I pulled the line and had no pressure. Rolled the engine with the MAF hooked up, no fuel. *sigh*
Simple stuff indeed!Contact me for information about Festiva Madness!
So, last night, when I pulled the fuel lines, and jumped the tester for the pump, I had fuel gushing. Like I said, there was no pressure tonight. Had the daughter crank it with tester jumped, no fuel. Pulled the pump out. Hooked it up properly to the battery. Nothing. Reversed polarity, "whirrr click."
Hooked it back up and it spun just fine. That temperamental little....... That sucker OK DOKIED me last night!
So, the sending unit on it was good, which my old one was NOT, so I swapped my old pump back in to the new sending unit, put it all back in, fired right up. YAY!
Hooking up exhaust next, then chasing down the high idle.Contact me for information about Festiva Madness!
And we are back to this fuel pump not working. It has what, approx 750K on it? No wonder. But for the other one to be bad too? I am skeptical. However, Boopstiva has a brand spanking cost WAY too much new Denso Fuel Pump in her. Pulling it out and trying it.Contact me for information about Festiva Madness!
Or, since I jacked it up to put the exhaust together, I might just be, for all intents and purposes, out of gas :banghead: and no, I wasn't out with the other one. For S&G's, I hooked it up again. No spinny.Originally posted by scitzz View PostAnd we are back to this fuel pump not working. It has what, approx 750K on it? No wonder. But for the other one to be bad too? I am skeptical. However, Boopstiva has a brand spanking cost WAY too much new Denso Fuel Pump in her. Pulling it out and trying it.
I am down to about an eighth a tank, and when we jacked up the passenger front, all the gas went to the rear drivers corner. DUH! I am recording this here as a chronicle for my stupidity and a lesson that skepticism pays
OK, just took a nice little test drive with the daughter. That was fun, and I can't even goose it hard yet!
Mo powah Mo Better!
Now, I still have to purchase another timing light, but even with the timing retarded pretty good, and the idle screw all the way in, I am running about 1200 PRM. Any ideas of why that might be?
Edit: The daughter says our fishing expeditions just got more exciting
Last edited by scitzz; 09-11-2012, 04:36 AM.Contact me for information about Festiva Madness!
vacuum leak? foot sitting on the gas pedal a little?Originally posted by scitzz View PostOK, just took a nice little test drive with the daughter. That was fun, and I can't even goose it hard yet!
Mo powah Mo Better!
Not a foot, vacuum, good idea. I have been after vacuum leaks for a while, and while I THINK I got them all, I ain't guessing! Anything else to check for while I got food cooking before I go back out there?Contact me for information about Festiva Madness!
maybe it is just extra raring to go!....lolOriginally posted by scitzz View PostNot a foot, vacuum, good idea. I have been after vacuum leaks for a while, and while I THINK I got them all, I ain't guessing! Anything else to check for while I got food cooking before I go back out there?"FLTG4LIFE" @FINALLEVEL , "PBH"
That must be it!Originally posted by GenevaDirt View Postmaybe it is just extra raring to go!....lolContact me for information about Festiva Madness!
Does the throttle cable have enough slack in it where it connects to the throttle body?~Nate
Current cars:
FOTY 2008 winner!
