HELP! SERIOUS STUTTER!
  • #16
    Replaced the Fuel filter. No luck... Hmm... What next?
    1990 Festiva L White: R.I.P.
    1988 Festiva L Silver: R.I.P.
    1989 Festiva L White: R.I.P.
    • #17
      I had the same exact problem in my ranger, as well as my CRX. In my Ranger AND my CRX, I checked the distributor and noticed that they had some water in there, so you may want to check that. Even though that helped a little, I replaced the plugs and wires which totally fixed the problem.
      Just my 2c
      • #18
        The plugs and wires were replaced in the last 6 weeks. I just remembered that it started doing this the next day after I replaced the Air filter. I'm not 100% sure, but I think the MAF wasn't plugged in tight. Could this possibly cause this issue?
        • #19
          Same issue in a jeep. Turned out the leads to the ignition coil would loose contact when the wire got warm and relaxed. As soon as it cooled off it was fine again. Took me a week to figure that one out... well my buddy did at least.
          Sent from my AT100 using Tapatalk 2
          HULi ---------------------------------------------------------------------------> Any-where, any-way, any-time.
          "CL4P-TP" - 93 Festiva L
          • #20
            ^^Definitely yes since if the air box is unplugged it will not run with throttle. Only idle.
            '89L 110k mi. BP/G swapped
            '90LX 68k mi. wrecked 12/14 RIP
            '90 F250 4X4 108K mi.
            '13 Kia Rio 5 LX 70k mi.
            '18 Kia Soul 40k mi. Daily
            '64 Studebaker Gran Turismo Hawk
            '66 International Harvester pickup
            • #21
              mine would do that when fuel was below quarter tank.. turned out fuel pump strainer in the tank was clogged
              • #22
                It won't run for more than a second or two without the VAF installed. If the vane doesn't move, the VAF "sees" no air entering the engine.
                Once the key is turned, the fuel pump stays on for only a second, then it's the VAF that runs the pump. The vane hits a micro switch at rest which opens the circuit to the pump. No air entering the engine, no fuel being pumped.
                -Zack
                • #23
                  Weird. My yellow car will idle unplugged until I touch the gas pedal.
                  • #24
                    Check the TPS if you didn't see those sparks.
                    • #25
                      MAF plugged in tight. plugs look good, distributor wiped clean (Though probably could replace the cap and rotor). I'm really starting to bang my head on this one.
                      Probably remove the fuel pump and check it out tonight. (In my past with Festivas/Aspires, the fuel pump either works or it doesn't right? I'm contemplating on the dirty pump bag filter).
                      Also, how do I check the TPS?
                      Weird... I ran the car for 15 minutes idling last night, and revving it up, and it didn't hesitate at once. I held it half throttle for like 2 minutes. NOTHING. What would cause it to buck under load (driving) but not at idle?
                      • #26
                        Another fun fact, that might have something to do with this issue. (Maybe?)
                        When I got to start the car, sometime it won't start. Like it won't send power to the ignition. It'll just sit there, wait a few seconds and it'll start. What would cause this? Could whatever is causing this, cause my stutter?
                        • #27
                          I don't think so, that sounds like maybe a loose connection at battery.
                          www.facebook.com/rhodestiva ;
                          rhodestiva@gmail.com ;
                          '92 Festiva L M/T
                          '93 Festiva GL A/T
                          • #28
                            Detach the connector from the throttle position sensor.
                            Connect an ohmmeter between terminals IDL and E.
                            Insert a 0.004 in. (0.1mm) feeler gauge between the throttle stop screw and stop lever.
                            Verify there is continuity between terminals IDL and E.
                            Then replace the feeler gauge with a 0.02 in. (1.0mm) feeler gauge, verify there is no continuity between terminals IDL and E .
                            Then open the throttle wide and verify there is no continuity again between terminals IDL and E.
                            Next, connect the ohmmeter between terminals POW and E.
                            Verify there is no continuity between terminals POW and E.
                            Then replace the feeler gauge with 0.02 in. (1.0mm), verify there is no continuity between terminals POW andE.
                            Then open the throttle wide and verify there is continuity between terminals POW and E.
                            When you are looking at the sensor connector, the pieces inside, from top to bottom, are:
                            POW
                            E
                            IDL
                            It probably isn't broken, but if it is out of adjustment, it COULD be causing your problems, and is such an easy check.
                            • #29
                              Re: HELP! SERIOUS STUTTER!
                              Have you checked the coil? Sounds to me like it is spark related and unless I missed it, you still have an old coil.
                              Sent from my DROID RAZR HD using Tapatalk 2
                              • #30
                                Cleaned the distributor cap. All is well.
