Originally posted by TheresGabe
HELP! SERIOUS STUTTER!
I had pretty much the same problem for awhile, (not gumout related just the stuttering) replaced everything from the throttle position sensor to the o2 sensor, fuel filter, MAF, etc.... it ended up being the fuel pump itself. got a new one off of ebay for less then $40.00 haven't had a problem since. hope this helps.pickster1107
Hi! Welcome to the forum! Always glad to see a new face, so to speak!Originally posted by pickster1107 View PostI had pretty much the same problem for awhile, (not gumout related just the stuttering) replaced everything from the throttle position sensor to the o2 sensor, fuel filter, MAF, etc.... it ended up being the fuel pump itself. got a new one off of ebay for less then $40.00 haven't had a problem since. hope this helps.
In regards to your post, you may notice my signature line. One thing is Diagnose, THEN replace. It saves tons of money. Wanna know how I know? Because I used to throw parts at a problem, until I started learning how to make a diagnosis. I would say that this site would help a LOT with that! There is so much info to be found with the search bar, that you can literally spend days reading and not learn it all! Hopefully, we can help you on this road
