I didn't know how much dirt had gotten into my gas tank. The dirt clogged the injectors and the fuel filter. The pump caused the 30 amp fuse to blow. So, I removed fuel tank and cleaned it out. I put the clean, dry tank back in. Since I had it out and the pump filter was clogged I decided to replace pump assembly. I installed a walbro 255 for an Eagle Talon. One tie-wrap, the +12 and ground had to be butt-spliced (blacks ground and blue-red positive) so the pump connector and fuel sending unit assembly connector can both be used. I put all back together, add 4 gallons and attempted to start car. No unmistakable walbo whine. Car would not start.
Next: checked fuse with meter, good. Checked inertia switch, it's good.
Pulled off connector to sending unit assembly and measured a good ground through inertia switch and 11volts on the 12volt side.
I next pulled the pump out and removed the walbro pump connector to measure continuity from top sending unit connector to pump connector. It measured a good connection.
I will next pull out the pump and remove from the assembly, and run 12 and ground to pump to see if it comes on.
I think I need a new, new pump.
