It was the drive gear. Speedo works fine now.
Aspire speedo gear problems.
So the new Speedo Rhodestiva sent fixed the problem? Glad it's working now!
good to hear.;
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
What is up with the three different speedo units? Grabbed one out of an Aspire at the j/y... was the short blue one!!! mine is the yellow one. Any ideas why some are comming up different? Possible different tranny builds available through different Aspires?HULi ---------------------------------------------------------------------------> Any-where, any-way, any-time.
"CL4P-TP" - 93 Festiva L
Going to ask here too. Anyone know the tooth count of both the gear going to the speedo cable and the gear in the manual transmission that it interfaces?
Sent from my DROID RAZR HD using TapatalkHULi ---------------------------------------------------------------------------> Any-where, any-way, any-time.
My current Aspire has gone thru several speedos, and it hasn't reached 200K miles yet. I think the Aspire speedo internals are inherently weaker than the Festy ones. My current one is having issues now with resetting the tripmeter. The speedos are pretty easy to swap out.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I must have phrased that incorrectly. I need the gear that drives the cable and the gear in the transmission that it rides on. Tooth counts for both.
I am trying to get my speedo adjusted and the company wants the counts for the calibration.HULi ---------------------------------------------------------------------------> Any-where, any-way, any-time.
^ Huli IIRC the Festy & Aspire are the same count numbers. To accommodate the different final drive ratio (which would change the speedo) the Aspire got larger tires. I dont know if this helps?Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Thanks, that is the math I need to get the numbers for. Without that ratio the speedo cannot be accurately produced.
Bsically... ratio of old numbers times speedo difference (.878 ) equals the amount of change made up in the adaptor box
Sent from my DROID RAZR HD using TapatalkLast edited by Huli; 12-22-2013, 09:37 AM.HULi ---------------------------------------------------------------------------> Any-where, any-way, any-time.
Adapter box?Some people like to read fiction,I prefer to read repair manuals. Weird I know-
