I went out the other morning and my stick 91 Festy, that had been running fine, would crank great but not fire. I sprayed some sf into the intake and it fired. It seems like it's not getting gas and the tank is half full. Anyone have some advice on this one?
Won't Start
Try the fuel cut off switch in the back over the rear wheel well. I think its on the driver side. I can't remember though. I know its not hard to get to you just have to take off the plastic and its a little black saqure mounted on the fender.'89 L Charcoal
'89 L Red
'91 Ranger
'65 F100
Sepmer Fi
ok I had a similar problem before and I started there. It turns out the relay that runs the injectors has corrosion in the wires. It was an easy fix just was a pain to diagnose. I just cut out the bad and put a weather proof butt connector in.Last edited by fastiva89; 03-09-2013, 09:17 PM.'89 L Charcoal
'89 L Red
'91 Ranger
'65 F100
Sepmer Fi
Another thing to check for. Air leak between the intake manifold and the VAF.Festiva: Because even my dog can build a Honda.
Won't Start
If the main power relay is bad I have an extra $25.;
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
