Won't Start
  • Won't Start
    I went out the other morning and my stick 91 Festy, that had been running fine, would crank great but not fire. I sprayed some sf into the intake and it fired. It seems like it's not getting gas and the tank is half full. Anyone have some advice on this one?
    Try the fuel cut off switch in the back over the rear wheel well. I think its on the driver side. I can't remember though. I know its not hard to get to you just have to take off the plastic and its a little black saqure mounted on the fender.
    '89 L Charcoal
    '89 L Red
    '91 Ranger
    '65 F100
    Sepmer Fi
      I tried that. There is a small square hole in the top of the rear trim panel, driver's side, below the rear speaker perch. You can use a mirror to look inside. The red reset button is just down inside the hole. Mine was still set. Thanks anyway.
        If you want to hear if the fuel pump is running you have to jump the test connector with a paper clip or similar conductor. It's located near the brake booster and is T shaped female. Key must be on.
          ok I had a similar problem before and I started there. It turns out the relay that runs the injectors has corrosion in the wires. It was an easy fix just was a pain to diagnose. I just cut out the bad and put a weather proof butt connector in.
          '89 L Charcoal
          '89 L Red
          '91 Ranger
          '65 F100
          Sepmer Fi
            Another thing to check for. Air leak between the intake manifold and the VAF.
              Festiva89.........where is the relay you fixed? thanks all.
              Going to try the fuel pump jump too. I know it only runs when cranking the engine.
                Won't Start
                If the main power relay is bad I have an extra $25.
                www.facebook.com/rhodestiva ;
                rhodestiva@gmail.com ;
                '92 Festiva L M/T
                '93 Festiva GL A/T
                  It was right behind the driver side headlight
                  '89 L Charcoal
                  '89 L Red
                  '91 Ranger
                  '65 F100
                  Sepmer Fi
