I also warm it up, then drive it up a hill and back. Taking out the tstat gets a little better velocity but it is harder to get the temp up to where the detergent is designed to work. Letting it idle until the cooling fan turns on then revving the engine within reason seems to help. Drive it for a day, time is definitely an important element when cleaning stuff, my hot water washer seems to like 20 minutes to wash parts super clean
Burp an engine? I have a tool that evacuates all air then sucks in the new coolant. With out the tool it is really hard to get all the air out. Those little coolant hoses, pick the highest one and leave the end off until coolant comes out then put it on and top it off.
Quantity? My box didn't come with a scoop but I would guess I used about a 1/4 cup per "cycle"
If stop leak or scum is sealing a gasket type leak that will get worse. A water pump seal could go either way. Thin soft plugs..at least they will be clean to work on!
