Yes unfortunately. Most spindle nuts aren't meant to be reused. Mine were trashed after being used once.
Rear tire almost fell off..!!
They seem to go on better the opposite way the were supposed to be like you said. I think im going to drill a hole in it and put a cotter pin as Bert mentionedOriginally posted by fastiva89 View PostYes unfortunately. Most spindle nuts aren't meant to be reused. Mine were trashed after being used once.
to make it more secure.Last edited by Dom; 03-16-2013, 06:07 PM.
Technically yes...Originally posted by Dom View PostAre these nuts supposed to be one time nuts ?-------------------------------------------------------------------------------------------
My Musica! Click me!
>_>.. my spindles are so bad, I've reused mine.. well, more than I'd like to admit. Let's say more than 5...Originally posted by Charlie1717 View PostTechnically yes...
~JoeWhite '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
1988 LX 5-speed
1993 L 5-speed B8, E series, Aspire/Rio swapped
Gone:
There is no real point in installing a cotter pin in hopes of keeping the clinch nuts in place (on those you smack the lip with a cold chisel to lock it on to the spindle groove). You will want to find the nut arrangement that has slots in it (ie castle nut) in order to do this properly.Originally posted by Dom View PostThey seem to go on better the opposite way the were supposed to be like you said. I think im going to drill a hole in it and put a cotter pin as Bert mentioned
You can get another "life" out of the nuts by installing a washer under them. This makes them stop in a different place, giving you a clean piece to punch into the slot in the axle. The washer (of course) has to be a good, hard steel one of the correct size, not zinc plated crap from the hardware store.
Yea thats what i ended up doing i chisel the nut on the groove and torque it to the spec. So far so good.Originally posted by Bert View PostThere is no real point in installing a cotter pin in hopes of keeping the clinch nuts in place (on those you smack the lip with a cold chisel to lock it on to the spindle groove). You will want to find the nut arrangement that has slots in it (ie castle nut) in order to do this properly.
