I was told by my friend who installed my transmission a couple months ago that I had an oil pan gasket leak so I've been putting in a little oil here and there and leaving a half dollar size spot just about anytime I parked anywhere. I've been waiting til I needed another oil change to address that gasket and was planning on doing that last weekend before I found out it was a little more involved than I was hoping and I had a trip planned for the weekend. I took my trip (roughly 550 miles during the weekend) and when I was getting close to home I noticed a ticking noise when in gear or giving it gas. I had heard this before and it was when I was quite low on oil. I got in around 10:30 Sunday night and didn't wanna mess with it. I figured I was low on oil so I didn't drive my car to work the last two days. After work today I moved the car back a bit to get it on leveler ground to start prepping for the oil change and pan gasket. Well that's when I found the underside of my car covered in oil and the Micro Machine had marked it's territory all over my driveway!
I had the valve cover gasket replaced several months ago and the rear main seal was done when I had the transmission swapped not long ago. I took a bunch of pictures to hopefully help narrow down where the leak is coming from. Is it just my pan gasket? What else could it be? Cam seals?
Here are the pics.
I've been leaking small amounts in several spots in my driveway for just about as long as I've owned the car...so it's mark has been spreading over the 10 months I've owned it, but you can see the darker/fresher spots from it sitting the last two days. The oil was so caked underneath that it was dripping off from the front of the gas tank!
Sorry about some of these. It's hard to take good pictures underneath a Festiva! Plus it was starting to get dark.
I guess the good news is there was some oil still in the pan! Though not much.
Here are the pics.
