Originally posted by zoom zoom
Valve seals Leaking on a BP.
Yea I've done a few myself, the throttle needs held wide open too, but the top ring is the compression ring, second ring wipes oil back down the bore, and the third lowest ring is the oil ring that squeegies the majority of the oil back down. So if compression is based on the seal the top ring makes, would the oil ring really have much to do with it? Aside from maybe letting oil stay on the walls, causing dry test numbers to be close to wet test numbers, or low compression if the compression ring isn't sealing at all...but the car runs so maybe there's hope after the rings get unstuck?Last edited by zoom zoom; 06-18-2013, 11:49 AM.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
it just randomly started this. i am hoping Mike is right about the PCV valve, that could cause oil leaks.;
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
Pull the pcv out and shake it. If the stopper doesn't move around in there freely it may be caked up by old dried oil. I had a b6t do this to me one time. The head was new. I couldn't figure out why it was smoking thought it was the turbo. Replaced the pcv it stopped.1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1989 Ford Mustang GT 5.slow
1996 Ford F-150
Update:
Check pcv valve and a little sludges up cleaned and working fine. Still smoke.
Added some seafoam to crankcase smoke dies a little. Removed spark plugs and added a little seafoam to each cylinder. And also looked down and not much oil on piston
now I will let soak for a while. Then tomorrow try to crank a run the seafoam out.
'92 Festiva L M/T
'93 Festiva GL A/T
Drove it for about 10 minutes around 10pm and it quicks smoking when warmed and driving like before. Will check again tomorrow and see where we are at. It all else I will be smoking all the way to FM7. Maybe I'll get best beater. Lol;
'92 Festiva L M/T
'93 Festiva GL A/T
A BP swapped Festiva that smokes a little I doubt will be anywhere close to be considered a "beater"Originally posted by RhodeStiva View PostMaybe I'll get best beater. Lol
I hope your planning on changing your oil in a day or two, don't run with seafoam in the crankcase for more than 50-100 miles, it will cause other problems you don't want.
I am really not even sure if you have an issue, almost every vehicle I've ever owned smokes a little on warm up. I write it off as moisture buildup and drive anyway. Does it smoke so bad that you can't see your hand in front of your face, or is it a concentrated stream that dissipates 10' from the car?Last edited by zoom zoom; 06-19-2013, 04:56 AM.2008 Kia Rio- new beater
When I accelerate it makes a giant thick cloud. Idle doesn't smoke bad at all. Drive for a little while almost goes away.;
'92 Festiva L M/T
'93 Festiva GL A/T
i will try next waiting on friend to bring me his. I just need to drive it to Greg and drop it off. But all signs now are pointing to rings.Last edited by RhodeStiva; 06-19-2013, 07:50 AM.;
'92 Festiva L M/T
'93 Festiva GL A/T
UPDATE:
cleaned pcv and hose
cleaned injectors
replaced valve seals
did compression test 120 on all cylinders
changed spark plugs
the pcv valve has a little oil goo in it getting a new one tomorrow.
STILL SMOKING!!!;
'92 Festiva L M/T
'93 Festiva GL A/T
Mine smokes a little on start up & a little more when I accelerate the engine. After it warms up it stops smoking. When I first got the car it smoked bad with a cold engine. Now that it's my daily driver, it hardly smokes at all.
I will be using high mileage full sinthetic motor oil. Hopefully it will help from not smoking.
I'm not too worried about it. The engine has alot of power and pep.1993 Ford Festiva L blue 170,000 miles
1990 Ford Festiva L Plus white 190,000 Auto, currently waiting to have another engine put in.
1995 Ford F150 XLT black 203,000 miles
2002 Honda CRV silver 180,000 miles
2003 Toyota Rav4 Sport black 94,000 miles
2008 Sym Rv250 dark grey 30,000 miles. My scooter.
1989 Ford Festiva LX black 233,000 miles. Sold to my better half's son.
Mike
Yea but mine smokes more than a little when I accelerate. I look like the mosquito man.;
'92 Festiva L M/T
'93 Festiva GL A/T
120 sounds low? was the throttle wide open, all plugs out, and about an ounce of oil dropped in the spark plug hole before you screwed the tester in?2008 Kia Rio- new beater
