I mean all the spark plugs were out. Didn't touch throttle.
Valve seals Leaking on a BP.
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
Yes one of those little filters.;
'92 Festiva L M/T
'93 Festiva GL A/T
The only other thing i can think of would be bad valve guides when the timing was off a little. i might of cracked one or 3. so i might go head shopping the weekend.;
'92 Festiva L M/T
'93 Festiva GL A/T
Did you test with some oil in the CC to see if it is bottom or top end?Any difference that makes no difference is no difference.
don't know how to do that? but can today.
do you just put a little oil in each cylinder through plug hole
then do the test again?;
'92 Festiva L M/T
'93 Festiva GL A/T
Yeah, before and after some oil in the cylinder. If pressure goes up with oil, rings are not sealing.Any difference that makes no difference is no difference.
'92 Festiva L M/T
'93 Festiva GL A/T
Looks like I will be driving to FM7 smoking no money for rebuild. It's ok I will just drive in front of M3NTAL this time.;
'92 Festiva L M/T
'93 Festiva GL A/T
I just don't have the right tools like engine hoist;
'92 Festiva L M/T
'93 Festiva GL A/T
I think I am go int to remove head and oil pan and hit the pistons out that way no engine removal required.;
'92 Festiva L M/T
'93 Festiva GL A/T
