Someone get Matt some ICE!!
Only getting 20 MPG?
Think it was off a tooth on intake side. Fixed and actually cranks better now. Hope it fixes gas issue will let know soon.
Sent from my iPhone using Tapatalk 2;
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
that pic shows a tooth advanced on the intake.Trees aren't kind to me...
Originally posted by FestYboy View Postthat pic shows a tooth advanced on the intake.
'92 Festiva L M/T
'93 Festiva GL A/T
At what speed are you over reporting by 5mph. If it's at 50mph that needs a 10% correction. If it's at 25mph that's 20% off...Last edited by mikeyjd; 07-30-2013, 07:22 AM.
it is 5 mph over at every speed going 50 mph it says 55mph.;
'92 Festiva L M/T
'93 Festiva GL A/T
there is a t-stat and it reads right in the middle between cold and hot.;
'92 Festiva L M/T
'93 Festiva GL A/T
size.jpg that is a 7.57 % increase in rpm so if i did the math right that is only a 2.27 mpg decrease and not a 10 mpg decrease .Last edited by RhodeStiva; 07-30-2013, 09:23 AM.;
'92 Festiva L M/T
'93 Festiva GL A/T
i will fill up soon and do a test and find out if it was the timing that was the issue.;
'92 Festiva L M/T
'93 Festiva GL A/T
It depends on your driving. If you used those wheels on the highway it will affect you more. But you should get better city miles. You are changing the gearing too when you change the size of the wheel.1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1989 Ford Mustang GT 5.slow
1996 Ford F-150
Just don't want us to stop every 5 minutes on the way to FM7. Trying to get it better.
'92 Festiva L M/T
'93 Festiva GL A/T
