you DON'T have to pull the crank bolt to do this job, especially on an 88-89. dont even have to drop the passenger mount, just remove pullies and covers and you're home free.
Water pump
Arty, I did know that about the crank bolt, I was just posting (a little off-topic) for those wanting to deal with the crank bolt at some time.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
fair enough, i just wanted to get this back on topic for Logan so he can get his 'lil beast back on the road ASAP.
it just seemed that once Logan asked how to remove that crank bolt (even though it was unsessisary for the job at hand), all subsequent posts fixated on that bolt, and if i were Logan, that makes this thread half a waste for me, ya know?
what i should do is stickie that writeup i did about doing the WP and timing belt, but even though i have Mod powers, i still can't stickie something. i'll talk to John about that later. and in the meantime, i'll work on other writeups for other common jobs.Trees aren't kind to me...
it depends on what all you pull off.... typicaly, VC and head gaskets, and downpipe gasket are the MINIMUM. If you had an EFI engine, a TB gasket would be added to that list.
you'll need a 12mm 12pt socket and extention with a long ratchet to loosen the head bolts. loosen each bolt 1/2 turn (going in reverse order) to keep from stressing the head. do this untill the bolts are finger loose.Trees aren't kind to me...
that's typical... it's usually the other way round: oil in the coolent. (if there's cross contamination)Trees aren't kind to me...
