Come someone give my the down low on ignition timing? I have a timing like but when I hooked it up the line never got close to the 10 degree mark.
Ignition timing help
I checked the timing belt several different times to make sure it was right. I will look at it and see. Don't I have to ground something when checking the timing?Originally posted by 1chrisapple View PostOk so u must have timing belt off a tooth or something.be easier if u just left everything in one thread.
I will look at it tomorrow. But my Haynes manual said ground a connector by the brake booster to the motor and then set the timing. But I checked the timing belt 3 times while it was off just to make sure it was perfect but I could have messed up. But I may have missed something somewhere. Another question I have is if the dizzy got turned the wrong way would the car still start and run? Like its lined up in the cam shaft wrong.Originally posted by 1chrisapple View PostI dont think so unless these have a spout connector.just hook pick to #1 wire and of course to battery.but then agian u can adjust the dizzy quite a bit just c if u can get lined up
Im not sure if it would run or not but if u set ur motor to tdc and set the dizzy rotor pointing towards the #1 wire on cap then should be good. But if u cant do that.then just pull dizzy out trun rotor 180 put back in and c what happens. Not trying to be rude but if you need walked through the whole timing setup deal call me at 502-264-1391
chris, if the dizzy is 180 out, something is very wrong. the dizzy drive shaft is offset to keep that from happening, as is the cam.Trees aren't kind to me...
My rotor has 3ways it can go on, if its not lined up it wont run. Timing belt deff sounds off a tooth, how far out is your timing. If you ground out the sti wire it will stop the pcmfrom advancing the timing, its how i do it, gives me the accurate timing.Yellow 91 festiva GL 5speed
Red 88festiva L 4spd
Blue 91festiva L 5spd (bad tranny, sloppy suspension)
Where is the STI wire? I have several wires by the brake booster.Originally posted by Jblair View PostMy rotor has 3ways it can go on, if its not lined up it wont run. Timing belt deff sounds off a tooth, how far out is your timing. If you ground out the sti wire it will stop the pcmfrom advancing the timing, its how i do it, gives me the accurate timing.
I'm gonna check the timing belt tomorrow just to be sure.Originally posted by 1chrisapple View PostIm not sure if it would run or not but if u set ur motor to tdc and set the dizzy rotor pointing towards the #1 wire on cap then should be good. But if u cant do that.then just pull dizzy out trun rotor 180 put back in and c what happens. Not trying to be rude but if you need walked through the whole timing setup deal call me at 502-264-1391
^ This.Originally posted by Jblair View PostIf you ground out the sti wire it will stop the pcmfrom advancing the timing, its how i do it, gives me the accurate timing.Dan
STI wire is a black plastic (white for carbys?) female plug, near the driver's strut tower/brake MC. It's the only one-wire plug there, I believe; there are several plugs there. Stick something metal into it and ground it against the motor. I use a spade connector permanently in the plug, which also makes it easier to find again, then use alligator clips to connect it to the motor. And yes, you do have to do this to time it properly.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
When I ground the black one and start timing the car as the mark gets closer to the 10 degree the car stalls out.
