I should mention to watch that darn clip! Mine flew off into the nether regions of my engine bay and possibly into the gravel driveway below. After an hour searching, I gave up and considered it a sacrifice to the car gods.
Hard to start first thing of a morning
Should it stay one way when I move it?? Never had a check engine light. I could walk out right now and it would start fine but when I get in it tomorrow morning it will be hateful.Originally posted by SiliconSoul View PostMake any difference at all?
Do you ever get an odd check engine light flashing on briefly?
Fuse links , after cranking a few min they get hot and make contact ?? In front left side strut tower three wire looking things , unplug and clean with your moms finger nail file , cars fixed and moms pissed D U N dunNew build on the way .
Did you try starting it while the sensor was unplugged?Originally posted by logan View PostShould it stay one way when I move it?? Never had a check engine light. I could walk out right now and it would start fine but when I get in it tomorrow morning it will be hateful.- Form should follow function...
No I didn't. I did find the coil was sparking tho and I put dielectric grease on all the connections and it stopped sparking so I hope maybe it was just static discharge that was causing it.Originally posted by SiliconSoul View PostDid you try starting it while the sensor was unplugged?
On the outside, side facing the firewall. And I've only noticed it while starting not after it does finally startOriginally posted by purg3d View PostThe coil should spark, but are you saying you can see a spark? From where exactly? With engine off, make sure your connections in that area are secure.
