Haynes manuals are cheap for the knowledge they provide. With that said, maybe this can help. http://www.yotatech.com/f116/spark-l...r-loss-137196/
Hard to start first thing of a morning
So I'm thinking a bad coil or bad wire. Can I just test resistance across the plug wires for to see if their good??Originally posted by purg3d View PostHaynes manuals are cheap for the knowledge they provide. With that said, maybe this can help. http://www.yotatech.com/f116/spark-l...r-loss-137196/
So I did some looking
1. The 3 wire connector to the module does not have voltage with key on instead all 3 act as a ground when going from + on battery to the connector.
2. When the car is running and I take a screw driver around the coil I get a spark from the coil to the screw driver and if left long enough the ca dies.
