Hard to start first thing of a morning
    I should mention to watch that darn clip! Mine flew off into the nether regions of my engine bay and possibly into the gravel driveway below. After an hour searching, I gave up and considered it a sacrifice to the car gods.
    - Form should follow function...
      It moved freely
        Make any difference at all?
        Do you ever get an odd check engine light flashing on briefly?
          Should it stay one way when I move it?? Never had a check engine light. I could walk out right now and it would start fine but when I get in it tomorrow morning it will be hateful.
            Fuse links , after cranking a few min they get hot and make contact ?? In front left side strut tower three wire looking things , unplug and clean with your moms finger nail file , cars fixed and moms pissed D U N dun
            New build on the way .
              Headed to do this now
                Did you try starting it while the sensor was unplugged?
                  No.
                  • #24
                    • #25
                      No I didn't. I did find the coil was sparking tho and I put dielectric grease on all the connections and it stopped sparking so I hope maybe it was just static discharge that was causing it.
                      • #26
                        Still doing it. Should the coil spark like it is?
                        • #27
                          The coil should spark, but are you saying you can see a spark? From where exactly? With engine off, make sure your connections in that area are secure.
                          • #28
                            On the outside, side facing the firewall. And I've only noticed it while starting not after it does finally start
                            • #29
                              • #30
                                Which plug? There's 3 different plugs around mine. One to the coil, one to the module and another one.
