if anybody knows of anybody who has springs I would be happy to pay plus the shipping or where I can get a pair at
front coil springs broken
I guess he put 2&2 together if its a Festiva and has broken springs is probably on YouTube from the previous owner doing something like that remember when you search for Festivus on YouTube you get about half drag racing videos from people on here and halfe a bunch of teenagers destroying them1993 GL 5 speed
and when I say teenagers I use the term loosely some actually teenagers and some aer quite older with a little bit of liquor in them making them turned back into teenagers1993 GL 5 speed
No, it is made from the same lot of coil steel. It is certified as meeting specification. Your car had to have been abused by jumping. That is the only way both front coils could have snapped in exactly the same spot. Does anyone know if springs are considered to be a safety item like brakes, seat belts and airbags?
If anyone bought a factory spring, there would be a triangle on the part label.Last edited by bravekozak; 11-07-2013, 10:51 AM.
I bet scrappers/ metal thieves tried to cut them off when his car was parked at the park and ride along the highway but when they realized they were made of COAL they just left them
$45 bucks on ebay could get you some honda coilovers.... I would go for the metal ones, not the coal ones. A tad stiffer ride though.Last edited by mikeand; 11-07-2013, 10:57 AM.1991 Smoketiva - 306k
1997 Jeep Cherokee - 4.6L Stroker
2004 Sebring
Wishful thinking that Ford might admit to a defective spring on a 16 year old car. Two of my Festys have had broken springs at one time or another and a 97 Aspire that I took apart a few years ago had broken springs all around. Typically this occurs through corrosion at contact points or inside the rubber boots.Originally posted by kensubaru03 View Postdo you think ford can do something if it was a factory defect ? maybe ? but how do I prove it ? I throw away the broken part alrighty , opps
Get yourself a set of early Rio springs from a U Pull or an auto wrecker; least expensive option.
