Rear Window Defogger Kit
  • #16
    He's talking about using a factory glass with def. Doesn't want to do that.
    I had no idea these were made. Interesting.
    • #17
      They are great aftermarket accessories and are easy to do. Just have to make sure you have a clean window. Plenty of open switch bays on the dash to add the defrost switch. They take about 30 mintues if you are super careful to do. I know I am kind of a chicken when it comes to glass. I hate working with it. Been cut way to many times and broke way to many windows to be anywhere near confident enough to work with it.
      • #18
        I have seen them in JC Whitney catalogs before
        • #19
          I did not find them in JCW the last time I checked, but I will look again
          • #20
            I have not seen another manufacturer with a backlite as large as a Festiva. That is one of the reasons I like the car. Great rear view. I do know I was unable to locate the rear defogger kit part number on Rear Counter. Most of the other backlites are either too small or curved. The same applies for adding a grid behind the front windshield wipers.
            • #21
              JC Whitney does not carry them. The grid system I used to install were all individual lines, each soldered to a strip at each side so it was completely custom. Then the main wire was soldiered to the side strip and ran to the switch up front which was hooked to a power source and a ground. Very easy to do. Very quick and not many could tell it was not factory.
              • #22
                Ford electric defrosting windshields. Very expensive option. DW792. I always knew gold was good for something useful.
                Retired Ford models.
                The Festiva rear defrost grid is unavailable. I wonder if Volvo sells their C30 rear defrost grid as a service part? I will check on Monday.
