They are great aftermarket accessories and are easy to do. Just have to make sure you have a clean window. Plenty of open switch bays on the dash to add the defrost switch. They take about 30 mintues if you are super careful to do. I know I am kind of a chicken when it comes to glass. I hate working with it. Been cut way to many times and broke way to many windows to be anywhere near confident enough to work with it.
91GL Green Auto DD There ain't no rest for the wicked
until we close our eyes for good. I will sleep when I die!
I have not seen another manufacturer with a backlite as large as a Festiva. That is one of the reasons I like the car. Great rear view. I do know I was unable to locate the rear defogger kit part number on Rear Counter. Most of the other backlites are either too small or curved. The same applies for adding a grid behind the front windshield wipers.
JC Whitney does not carry them. The grid system I used to install were all individual lines, each soldered to a strip at each side so it was completely custom. Then the main wire was soldiered to the side strip and ran to the switch up front which was hooked to a power source and a ground. Very easy to do. Very quick and not many could tell it was not factory.
