How involved is it to install an a/c in a Festy that does not have one in it?
Installing an a/c in a Festy......
1993 Ford Festiva L blue 170,000 miles
1990 Ford Festiva L Plus white 190,000 Auto, currently waiting to have another engine put in.
1995 Ford F150 XLT black 203,000 miles
2002 Honda CRV silver 180,000 miles
2003 Toyota Rav4 Sport black 94,000 miles
2008 Sym Rv250 dark grey 30,000 miles. My scooter.
1989 Ford Festiva LX black 233,000 miles. Sold to my better half's son.
MikeTags: None
Not too hard, still getting mine sorted before getting it charged. I should have changed the seals before installing it.lol
Sent from my SPH-M950 using Tapatalk1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
hypothetical if you buy a $300 Aspire that has complete cold AC is it worth it to try and use all of that system into a Festiva and if you need a few adapters for some hoses is it still worth it where is the slippery slope of money pit start1993 GL 5 speed
The components under the dash ..... How hard was that to install? Also the wiring, did you have to run your own wiring to get it to work? I'm not good with under the dash stuff.Originally posted by TorqueEffect View PostNot too hard, still getting mine sorted before getting it charged. I should have changed the seals before installing it.lol
What do you mean "should have changed the seals"?1993 Ford Festiva L blue 170,000 miles
Mike
Little o-rings are on the end of each pipe connector.Originally posted by muleskinner View PostThe components under the dash ..... How hard was that to install? Also the wiring, did you have to run your own wiring to get it to work? I'm not good with under the dash stuff.
The under dash stuff is easy.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
The connectors under the dash are just hanging there waiting for you to plug in.
You just have to remove the plastic duct tube and replace it with the condenser, then pop out the two firewall plugs and push on the rubber condenser drain elbow.
Most of the work is bolting on the compressor, evaporator, dryer, hooking up the hoses, routing the engine A/C harness, driving it in for a pressure test and charge.
Sounds easy!
umm, the lower pulley on the engine. is it supposed to be a double pulley to carry the compressor belt too?1993 Ford Festiva L blue 170,000 miles
Mike
Well it is a pulley the bolts onto the crank pulley, so yes it makes it a double pulley, because the ac is driven off a completely separate beltOriginally posted by muleskinner View PostSounds easy!
umm, the lower pulley on the engine. is it supposed to be a double pulley to carry the compressor belt too?1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
Inner A/C pulleyOriginally posted by TorqueEffect View PostWell it is a pulley the bolts onto the crank pulley, so yes it makes it a double pulley, because the ac is driven off a completely separate beltLast edited by bravekozak; 11-27-2013, 08:12 AM.
89 FBC A/C wiring diagram
89 EFI A/C wiring diagram
Note: Factory carb has two A/C relays, factory EFI has three A/C relays.Last edited by bravekozak; 11-27-2013, 06:34 PM.
I have a successful A/C install. I will be happy to give you pointers with your install. Be sure you have some good, sharp recip saw blades before you start.
Thanks, I will need your help. When I get all the components together, I will let you know!Originally posted by bravekozak View PostI have a successful A/C install. I will be happy to give you pointers with your install. Be sure you have some good, sharp recip saw blades before you start.
That's funny!! LOL!Last edited by muleskinner; 11-28-2013, 11:40 PM.1993 Ford Festiva L blue 170,000 miles
Mike
