Installing an a/c in a Festy......
  • Installing an a/c in a Festy......
    How involved is it to install an a/c in a Festy that does not have one in it?
    1993 Ford Festiva L blue 170,000 miles
    1990 Ford Festiva L Plus white 190,000 Auto, currently waiting to have another engine put in.
    1995 Ford F150 XLT black 203,000 miles
    2002 Honda CRV silver 180,000 miles
    2003 Toyota Rav4 Sport black 94,000 miles
    2008 Sym Rv250 dark grey 30,000 miles. My scooter.
    1989 Ford Festiva LX black 233,000 miles. Sold to my better half's son.
    Mike
    Not too hard, still getting mine sorted before getting it charged. I should have changed the seals before installing it.lol
    Sent from my SPH-M950 using Tapatalk
      hypothetical if you buy a $300 Aspire that has complete cold AC is it worth it to try and use all of that system into a Festiva and if you need a few adapters for some hoses is it still worth it where is the slippery slope of money pit start
      1993 GL 5 speed
        The components under the dash ..... How hard was that to install? Also the wiring, did you have to run your own wiring to get it to work? I'm not good with under the dash stuff.
        What do you mean "should have changed the seals"?
        Mike
          its all an easy swap including the under dash parts
            Little o-rings are on the end of each pipe connector.
            The under dash stuff is easy.
              The connectors under the dash are just hanging there waiting for you to plug in.
              You just have to remove the plastic duct tube and replace it with the condenser, then pop out the two firewall plugs and push on the rubber condenser drain elbow.
              Most of the work is bolting on the compressor, evaporator, dryer, hooking up the hoses, routing the engine A/C harness, driving it in for a pressure test and charge.
                Sounds easy!
                umm, the lower pulley on the engine. is it supposed to be a double pulley to carry the compressor belt too?
                Mike
                  Sounds easy!
                  Well it is a pulley the bolts onto the crank pulley, so yes it makes it a double pulley, because the ac is driven off a completely separate belt
                    Inner A/C pulley
                      It's really not hard at all. I did it in the carwash parking lot by the vacuums in a few hours lol.
                      I live in a desert, no garage no shade. Don't judge.
                      06 Jeep Cherokee Overland
                      95 Aspire (sold)
                        Sounds easy!
                        I have the pullies and spaces u need $20 shipped
                          89 FBC A/C wiring diagram
                          89 EFI A/C wiring diagram
                          Note: Factory carb has two A/C relays, factory EFI has three A/C relays.
                            I have a successful A/C install. I will be happy to give you pointers with your install. Be sure you have some good, sharp recip saw blades before you start.
                              Thanks, I will need your help. When I get all the components together, I will let you know!
                              That's funny!! LOL!
                              Mike
