Cap and rotor
  • Cap and rotor
    What is the best dist cap and rotor to buy ?
    I'm thinking Bosch or Nippondenso. The Bosches are made in Japan BTW! Probably by ND.
      I'm using Bosch no problems.
      1990 Red Festiva STOCK "pregnant roller skate"
      1989 Yellow Festiva BP swap "Freebird"
      2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
      2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
      2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
      1994 Ford F150 5.0 Completely stock.
        Currently running a cheapo ones from Oreilly's, no problems to report.
        Sent from my SPH-M950 using Tapatalk
          I'm running Standard ignition rotor and cap. The cap has brass terminals instead of the aluminum.
            Brass is better, yes? I think aluminum builds up resistance the more it's used, right?
              I think the aluminum are actually platinum coated? If you try cleaning the contacts you rub off the platinum and they are ruined. Happened to me on my last cap so was happy to see the brass contacts on the one I got from Standard.
