What did I do wrong? Why wouldn't the stat open? The upper hose is not hot at all. I drove 5 miles and the thing died and it was smoking like crazy. I let it cool down and drove home with flashers on and going 35 stopping about every mile to let the thing cool down and going again. What on earth did I do wrong? Please, any help will be appreciated. Its not leaking at the housing. I hope I don't have to put another stat in because I super glued that bad boy in. Hope I didn't do any permanent damage AHHHHHHHHHHHHHHHHH
HELP!! Just changed thermostat. Car overheated bad!!!
Didja put it in backwards? The spring should face into the head...Contact me for information about Festiva Madness!
I was going say same thing I done that before myselfOriginally posted by scitzz View PostDidja put it in backwards? The spring should face into the head...1990 Red Festiva STOCK "pregnant roller skate"
1989 Yellow Festiva BP swap "Freebird"
2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
1994 Ford F150 5.0 Completely stock.
super glue....hmmmmmm"FLTG4LIFE" @FINALLEVEL , "PBH"
I put it in the correct way. Spring in towards engine and bypass thingy up. I read on this forum about what stat to get and how to install. I used the super glue to keep the stat in place so I wouldn't crack the housing when tightening it down. Think I just have air in the system? Thanks, Jim
could be air I had a car last week with air in the lines and it was running hot.. get set of ramps drive car on them and put spill proof funnel in the cap fill up the funnel with coolant and run car with heat wide open until the bubble pops out..1990 Red Festiva STOCK "pregnant roller skate"
Not trying to be a grammar nazi but at least use some punctuation and Caps would not hurt, would make reading what you wrote much easier.Originally posted by 90fastiva View Postcould be air I had a car last week with air in the lines and it was running hot.. get set of ramps drive car on them and put spill proof funnel in the cap fill up the funnel with coolant and run car with heat wide open until the bubble pops out.."FLTG4LIFE" @FINALLEVEL , "PBH"
It should if that's what it is. Could take awhile. In ran one 4 hours once to get air out.1990 Red Festiva STOCK "pregnant roller skate"
Oh, MAN, found hole....picture.
So I walked to the store and bought some antifreeze. Getting ready to try and burp the air out of the system. I start pouring the antifreeze in and I hear a stream drizzling to the ground. What the?!?!? I bet this happened when I was trying to get to the last bolt. I had to pry up on the tube to get the socket on the nut. Can you think of anyway I can repair this? It leaks fast and hard a steady stream. The hole is on the bottom of the tube picture, where the arrow is pointing. Man!! Should of just lived with the lukewarm air I was getting.
There is a replaceable O ring in there. Try replacing it first. I have a good water line if you need it-Greg
Redneck Engineer
FOTY - '09
It helps if you can park the car so that the rad cap hole is "uphill" from where the upper rad hose connects to the rad. This way the bubbles will naturally come to the cap hole, and pop.Originally posted by jimdigs View PostSo the bubbles would come out of the top where the radiator cap goes? Thanks, Jim90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I did have it parked on an incline like you suggest. The thing just started leaking like a sieve, that's when I found the hole or leakOriginally posted by TominMO View PostIt helps if you can park the car so that the rad cap hole is "uphill" from where the upper rad hose connects to the rad. This way the bubbles will naturally come to the cap hole, and pop.
