This is only my opinion and your mileage may vary.
Parts needed;
Head gasket
Valve cover gasket
Possible parts needed;
Throttle body gasket
Exhaust pipe to manifold gasket
Parts that may as well be changed while you're there;
Timing belt
Water pump
If you desire to change the head gasket then pull the whole head, manifolds and all, at the same time.
Diconnect the battery.
Drain radiator.
Disconnect and label all wires, hoses, cables, etc. Disconnect the exhaust at the pipe/manifold connection.
Remove valve cover. This may require removing the front portion of the throttle body.
Remove head bolts.
Remove head.
Chances are there will be coolant and oil that gets into the cylinder bores upon the head being removed.
Grab paper towels and soak up the coolant and possible oil from the cylinders.
Clean gasket mating surfaces and check or have someone check the head for flatness.
Install head gasket. Install head. Torque head bolts in sequence in a couple of steps to final spec.
Install all related parts/pieces that were removed except the timing belt.
Install timing belt, aligning the marks.
Change the oil.
Top off the radiator.
Start engine.
This is a rather over simplification but gives a general gist and doesn't include absolutely every step.
It's not that difficult of a job. Simply time consuming.
Parts needed;
Head gasket
Valve cover gasket
Timing belt
Water pump
Drain radiator.
Remove head bolts.
Remove head.
Change the oil.
Start engine.
