Originally posted by jimdigs
I would say probably the easiest way would be to unbolt the lower radiator hose tube from the water pump to separate the 2 sections of tubing.
Judging from the pic you posted the tube seems rather crusty. If the inside of the tube is as bad you may have a difficult time trying to get it to seal.
I would try the "O" ring first and if that doesn't work, eurotiva has a replacement tube.
Or you could cut the flange off the tube and slip a piece of heater hose over the remains. I did that on my '89 a couple/few years back and it's held ever since.
Hope this helps.
