Hecka...have you tried just tightening the nut up to take up the play in the bearings? They may be fine. Unless you are getting humming or grinding sound then I would not mess with them. If you do need to change them it is such a simple job,provided they are just worn and not falling apart and stuff. A punch or an extension and a hammer is all you need to do the job. Oh, some new grease too.
Just watched your vid....looks like it just needs tightened. Get a new crush nut if you can...a dull chisel also would help to stake it once tightened...but not necessary.
