Alright awesome thanks I don't think I've been able to get fast enough to even use 5th gear lol
exploded clutch
It will work. When it comes to the flywheel, there is a torque spec you need to follow, AND you are supposed to use blue loctite. Don't forget the loctite! Specs are in Haynes, I can look it up for you if you want. If you don't own a torque wrench, go buy one. Trust me.Contact me for information about Festiva Madness!
I did use blue lock tight... But Yea should have used the torque reach.. Lesson learned the hard waybut I'll be using the red lock tight a semi mechanic told me. And I got my manual in my truck so I'll pull it out to finish it up thanks for the help
1993 festy "white stallion" BP swap with 7" lift, 1ton wench
R.I.P. 1991 festy "the festiva" stock b3, atv bumper, 8' whip
Originally posted by chris (Festiva) View Postbut I'll be using the red lock tight a semi mechanic told me.
Wow, how hard to you want to work to get them out next time? ;PContact me for information about Festiva Madness!
Originally posted by scitzz View PostWow, how hard to you want to work to get them out next time? ;P1993 festy "white stallion" BP swap with 7" lift, 1ton wench
MAZDA specifically calls out for a small amount of Black RTV on the Fly Wheel Bolts to help seal . Loctite on those threads is a mistake,but thats my 2 cents. Just sounds like the bolts where under torqued...Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Yes great question Chris.There is a tool but you dont need it.Have someone hold a large pry bar or screwdriver with the tip in between two teeth of the flywheel. And position the bar so that it contacts one of the two dowel pins (they align the tranny). Then as you torque they just keep the bar in place. You can also put a socket and breaker bar on the front crank bolt. But when you get used to the pry bar method you can do this by yourself very quickly(but its kinda like patting your head and rubbing your belly in a circle)meaning it takes a little practice......Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Originally posted by nitrofarm View PostMAZDA specifically calls out for a small amount of Black RTV on the Fly Wheel Bolts to help seal . Loctite on those threads is a mistake,but thats my 2 cents. Just sounds like the bolts where under torqued...
Running around outside the asylum again with my tappy talky appyContact me for information about Festiva Madness!
^ Ford Service ManualSome people like to read fiction,I prefer to read repair manuals. Weird I know-
Originally posted by nitrofarm View PostYes great question Chris.There is a tool but you dont need it.Have someone hold a large pry bar or screwdriver with the tip in between two teeth of the flywheel. And position the bar so that it contacts one of the two dowel pins (they align the tranny). Then as you torque they just keep the bar in place. You can also put a socket and breaker bar on the front crank bolt. But when you get used to the pry bar method you can do this by yourself very quickly(but its kinda like patting your head and rubbing your belly in a circle)meaning it takes a little practice......1993 festy "white stallion" BP swap with 7" lift, 1ton wench
You can also install a bolt in the engine where the Bell Housing bolts go and use that a a place to set your bar. Sometimes if you get lucky you can actually make a little "Cradle" with the built in washer area of the bolt. Then set the bar in and finger tight the bolt till it gets sandwiched between the bolt and the block. I'm sure you'll you figure it out because you need the car.Just remember to follow the crisscross bolt tightening sequence and use a good torque wrench. If you feel better use blue Locktite,but please dont use Red.Last edited by nitrofarm; 01-24-2014, 09:52 PM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Lol I'll use blue I guess.... But Yea I do the crisscross thang for every thang and I'll try everything till I find one that works! And Yea I need the car so I can get people to beleave me even with pics they think it's a joke and don't think it's possible for a 7" lifted feisty lol1993 festy "white stallion" BP swap with 7" lift, 1ton wench
Originally posted by nitrofarm View Post^ Ford Service ManualContact me for information about Festiva Madness!
