What is this trans sensor? Trans Problems.
  • What is this trans sensor? Trans Problems.
    What is this sensor located on the bottom of the trans? The wires have been ripped out.
    Also the car is having an odd problem. Just replaced the clutch and pressure plate. Clutch pedal feels good, trans shifts normal with the car off. If I start the car, while i's idling, the trans will not come out of neutral, as if there is a lock out. Now if I turn the car off, put it in gear, start the car, the clutch works fine and the car drives great, but as soon as I go to shift to the next gear the car gets stuck in neutral again! Any ideas?
    At first I figured the clutch fork wasn't pushing the pressure plate enough to engage the clutch, stopping me from being able to shift. But after starting it and driving it around the block in 2nd with completely normal pedal feel I'm stumped.
    '93 BP-T 57trim TO4E - Coilovers - 13x7 steelies - 175/60 - 48k mi
    Reverse sensor. For your backup lights. Did you replace the throw out bearing? Sounds trans related the fork shouldn't change off to on. How tight is the cable going to the trans? My mustang did this when the cable was maladjusted. But It wouldn't start in gear without rolling.
    1989 Ford Mustang GT 5.slow
    1996 Ford F-150
      The backup lights still work! I thought the reverse sensor was on the bell side of the trans?
      I've tried tightening/loosening the cable with no change in results.
        That is the fourth gear switch. When this switch is grounded, the ECA then knows when not to send a shift signal in top gear. Does anyone shift when the shift light comes on in your cluster? I don't and neither does BUSTIVA.
          Oh ok that makes sense. I don't remember it ever being hooked up, but I'm just trying to zero in on all problems before I pull the motor back out.
          I'm still stumped on the shifting issue.
            Was the throwout bearing put on in the proper direction?
              Yeah, didn't change it. All I touched were the pressure plate and the clutch disc. Throwout bearing was in perfect shape.
                Is that the stock tranny?
                On the G series, that would be the neutral safety switch which doesn't need to be hooked up
                As for the gear issue... Might sound silly but is the copper washer in behind that little sensor?
                On my tranny I once installed the sensor without the washer (didn't realize it was missing until later lol) and it would not go into any gear, similar to what you described, might be worth a check lol
                  Yes stock trans. I'll check for the washer.
                  Other than that the only thing I can think of is the new clutch's throwout bearing was specific to the pressure plate (different from my last one), and that is causing the clutch to not engage.
                    Guess I'm going to pull the motor/trans back out to look at the pressure plate.
                    Can anyone think of a way I could test the clutch engagement while its out of the car?
                      The reason this happens is because you're getting insufficient throw out bearing travel to release the fingers on the pressure plate.
                      Try this, before you pull it. While pulling back on the transaxle release lever, measure the clearance between the lever and the cable pin. Thread the adjuster in or out until the clearance between the pin and the lever is 1.5 - 2.5mm (0.06 - 0.10 in.)
                      Then check free play on your clutch pedal.
                        I've seen similar symptoms... clutch plate was installed backwards. But usually it makes some bad noises while driving with it this way (if you start it in gear, you can drive it with a whine, otherwise you can't get it in gear).
                        ~Nate
                        Current cars:
                        FOTY 2008 winner!
                          Haha. Well who would ever put a clutch disk in wrong ??
                          New build on the way .
                            When I was installing the pressure plate I noticed the fingers looked closer to the disc than normal, but figured it was just how this brand was. I think the disc hub is preventing the fingers to have enough movement to release the pressure plate.
                              I've actually seen it done 3 times! First was on an aspire, then the white B6t car, then after seeing two other people do it I just had to go and do it myself a few months ago. 0.o
                              I swear someone snuck in behind me and flipped it!
                              ~Nate
                              Current cars:
                              FOTY 2008 winner!
