What is this sensor located on the bottom of the trans? The wires have been ripped out.
Also the car is having an odd problem. Just replaced the clutch and pressure plate. Clutch pedal feels good, trans shifts normal with the car off. If I start the car, while i's idling, the trans will not come out of neutral, as if there is a lock out. Now if I turn the car off, put it in gear, start the car, the clutch works fine and the car drives great, but as soon as I go to shift to the next gear the car gets stuck in neutral again! Any ideas?
At first I figured the clutch fork wasn't pushing the pressure plate enough to engage the clutch, stopping me from being able to shift. But after starting it and driving it around the block in 2nd with completely normal pedal feel I'm stumped.
