Originally posted by nitrofarm
Completely stumped: High Idle Carby
Try pumping gas pedal? When starting the engine I let it run for about 10 seconds and then press the accellorator to release the choke.
Assume you've tried the white plastic idle adjustment screw on the left side of the carb?Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Originally posted by WmWatt View PostTry pumping gas pedal? When starting the engine I let it run for about 10 seconds and then press the accellorator to release the choke.
Oh yeah, I turned it until it does nothing, got it down to 2500. Revving it to let it kick down lets it kick down. You can see the little weighted piece move out of the way, then it idles at about 3K before sloooooooooowly dropping back down.Contact me for information about Festiva Madness!
Tom kind of pointed in the right direction. I would call it the base idle screw. Missing on daughters Carb.
It is where I am pointing here.
Finagled a small screwdriver in there and dialed it down. Viola. Set the rough idle and rolled. Thanks guys!
Running around outside the asylum again with my tappy talky appyContact me for information about Festiva Madness!
Sometimes its that easy-Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Glad you got it!!!Dan
