My new engine is running sluggish and I need to make sure timing is correct. I had to put on my own distributor as it didn't come with one.
I have the timing covers and pulleys off now. I checked the crank and cam marks and they line up fine. (So much for my theory that I was off a tooth.)
I had become under the impression that lower pulley timing marks between B3 and B6 were different, and I had changed my old lower pulley mark to match the B6 lower pulley (or what I thought was it's original lower pulley--maybe I got it from somewhere else?) mark. They were considerably different locations.
My B3 lower pulleys have two scratched mark locations right near the lone pointer when everything is TDC, as in the shop manual. This is just to the left of 12 o'clock.
The B6 (?) lower pulley has one scratch mark at around 1 o'clock or one-thirty position.
Rockauto indicates timing cover gasket sets are the same for B3 and B6. I think timing covers are the same, with same pointer locations, etc.
I'll paint the markers & put everything back together and put the timing light on it. I hope I'm just way off timing.
I had timed my old B6 with the changed mark. Maybe that shortened the head gasket seal somehow? I'm pretty sure changing the timing mark on the pulley didn't help.
Any ideas or advice welcome!
