OK I got my newly bought country yard find, 88 festiva lx home and digging on in.
Its been setting for five years+ , so before any thing I pulled the fuel pump and sucked out a small amount of bad gas. Tested the pump and its done so Ive got one ordered.
Next I disconnected fuel line and filter( gonna replace). I got itching to hear it run Somehow so I sprayed gas into the intake and turned it over and she runs!
So I wanted to see if injectors works so I tried pouring gas into the piece of line to the fuel rail and I hooked up an air hose first 5psi then 10 then 15 and no luck she won't run.
So I pulled injectors and tested theem buy hooking up a charge and blowing through , they all work.
I even ran injector cleaner through them and I did pour alil marvel oil in each plug hole a while before start up.
But the only way she runs is with gas sprayed into intake.
Any suggestions while I wait for the pump!?
