Hey. Stop. Install a fuel pump and make sure intake hose is connected to vaf and then try to start . It needs constaint fuel pressure to run . You can't make valid claims by blowing gas down the line with your air comp. your causing a lot of false problems .
wont get gas
Fuel pump is coming next business day.
I cheched efi and wire is fine and I cleaned the connections.
I read a thread on a ford forum that said that injector power can be off if a oil pressure sending sensor is bad.Last edited by grantjp; 05-25-2014, 03:38 PM.91 festiva L five speed red/black
74 Honda cl200
89 festiva Lx efi automatic grey
90 festiva L aqua blue parts car
That might be true for a more modern engine.Originally posted by grantjp View PostI read a thread on a ford forum that said that injector power can be off if a oil pressure sending sensor is bad.
But, I'm pretty sure the '88 or even '93 festiva isn't one of them.
I with Shadtree, until you have fuel rail pressure you not going to get good info on why your not getting ignition.'93 Blue 5spd 230K(down for clutch and overall maintanence)
I have no power at my injectors I have all unplugged and I see were someone has replaced all but #3 they spliced in different connectors.
I turn the engine over with my tester on the injector wires and no power, also no power at my fuel pump wires as well.
Someone just tell me its a relay or son.
Both my head lightsbulbs are gone any safety ideas91 festiva L five speed red/black
74 Honda cl200
OK I got a digram and am now even more confused as to where to start.
I'm thinking PARTS car.
She's only missing driver side window, left driveshaft and radio trim cover.91 festiva L five speed red/black
74 Honda cl200
I'm a stupid dummy, got the fuel pump today, Wrong, it was a inline electric pump for carb. So I paid a lil more attention and am now rewaiting for the right one.
Could get it from advanced or orileys for 130$ or 30$ online and use that hundred on more parts.
Plus its airtex so ok91 festiva L five speed red/black
74 Honda cl200
Got the new pump installed. I noticed with my line disconnected, it only pumps while I am cranking instead of like how most cars pump with ignition on.
Unfortunately she will not fire up. I believe I am not getting power at my injectors,
Followed wire diagrams and dang.
What would you look at first
I hate electrical issues. Help me91 festiva L five speed red/black
74 Honda cl200
What does the switch behind the gas pedal control?
With my ignition on I hear under the hood like a relay clicking but I can not find it.
I do not have one on my 91 four speed only automatic91 festiva L five speed red/black
74 Honda cl200
it does have the ac. my four speed does not. that would make sense.
im just digging to find the solution to my injector prob.
looks like im just gonna have to start replacing parts.91 festiva L five speed red/black
74 Honda cl200
You going to open up the non-functional relay and see what the issue was?'93 Blue 5spd 230K(down for clutch and overall maintanence)
Oh yeah a lil glue or something in the points, it now works as well.
Now I'm gonna pop a CV Axel in and find out about my trans mission and we will go from there.91 festiva L five speed red/black
74 Honda cl200
got the cv axle in and trans is fine.i took it a couple of miles down the roadand good deal. now i just got to put in the new radiator.
i have a few more issues like tac stuck at 1000 ? check engine light and so on and on91 festiva L five speed red/black
74 Honda cl200
