rear drum brake swap?
  • #76
    I see it now thank you if i can't get it i will be doing that
    Sent from my ZTE_N9511 using Tapatalk
    • #77
      How much should a spindle cost me at jy?
      • #78
        I've seen them as low as $15 and has high as $30, understand new in a box they were $60.
        • #79
          If it's a mom and pop yard like the ones close to me. $3-5 if you have other stuff also. $5 otherwise.
          -Bryant
          • #80
            Ok hacked off part of axle backing plate no good spindle is having allot of terrible getting nuts and bolts off spindle cost 25$
            • #81
              Might have been easier to have cut the strut at the lower bushing to get it out of the way, so you could get to the nuts on the back side of the backing plate.
              There are NO bolts on the spindle.
              You Must remove the nuts from the back side of the spindle.
              What looks like bolts on the front side of the backing plate are actually studs that go through the spindle and locate the backing plate.
              They can not be loosened, only the nuts.
              After all the nuts have been removed, you still might want to tap the studs to get the spindle free.
              • #82
                Cut the strut they are just rusted solid
                • #83
                  • #84
                    Please tell me you weren't the one who rounded the hex heads of the studs!
                    Your going to need to clean the spindle up from the nicks I see in the pic.
                    Some fine emery cloth or find sand paper and then a good cleaning with oil and a try cloth to get the steel powder removed.
                    Can't tell for sure, but that looks like it has the hole in it for the castellated nut/nut/keyed washer, is it?
                    Also compliments of Lessersivad:
                    We should have looked on U tube first, might have saved you a lot of time and helped you to understand what your looking at.
                    • #85
                      I know there was a pin in that had to be taken out to get off.i know one of the studs also came out some how that's not to bad and can go back in.i will work on getting the Knicks out of it.
                      • #86
                        Yes, that is the cotter pin.
                        Do you have another to replace it.
                        Can drop you a few in the mail if you need.
                        I know one of the studs also came out some how that's not too bad and can go back in.
                        Yeah not too bad, just tap it back in, or before you mount it to the back plate and rear beam put some PB Blaster on it.
                        When you tighten the nut it should pull it back into the mount.
                        How do the nuts look?
                        Can they be cleaned up?
                        Or do you need new ones?
                        I will work on getting the Knicks out of it.
                        DO NOT use Course sand paper.
                        You just want to take the nicks out, you don't want to scar the rest of the bearing surface, which looks OK.
                        I'd use 600 or 800 grit sand paper and be very careful.
                        • #87
                          no i do not have another cotter pin,where may i get one? i need to get replacement nuts the old ones were destroyed getting them off.
                          • #88
                            i don't think I'm going to be able to and it out its kinda bad ding. Is this going to cause a lot of problems?
                            • #89
                              Good news is its not where the bearing sets at, you should be ok.
                              As for cotter pins I just got a hole box of assorted sizes from autozone for about 5 bucks.
                              • #90
                                ok so i mostly have everything i think, i dont have any pieces for the spindle tho. can i get those at autozone?
