My car is driving me crazy
  • #31
    i know it is kind of a taboo subject but for me using MMO do wonders in my carby. Also, did you change the air filter?
    • #32
      As in Marvel Mystery Oil? In the gas? And yes, new air filter. Forgot to put that on the list.
      • #33
        Figured something else out. My alternator is junk. Think that could cause these problems?
        • #34
          Yeap, marvel oil, 16onz in a full tank. When I changed mine( put a B6 alternator) it did improved greatly the idle...
          • #35
            Should I go with a stock alternator or upgrade? If upgrade, what do I look for?
            • #36
              Almost any alternator from a Mazda will work (later Festivas, Proteges, MPV vans, Ford Probes ect). Although, I upgraded and had some issues. I say stick with stock; plug and play, no wiring hassles.
              Replacing my alt seriously helped with idle. I was having something that seemed like a miss before replacing.
              White '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
              1988 LX 5-speed
              ​​​1993 L 5-speed B8, E series, Aspire/Rio swapped
              Gone:
              • #37
                I've noticed even having a bad belt, or improper belt tension, can cause issues.
                - Form should follow function...
                • #38
                  I looked my car over the other day and the wire out of the O2 sensor was bent down some. I straightened ot out and checked connections. I also pulled the air cleaner and looked the carb over. Couldn't see a lot. Tried to make sure the wires were intact to the solenoid that is controlled by the ECU to control primary fuel mixture . Nothing obvious. Took it for a drive today and it ran fine. Intermittant problems are the worse. I'll probably drive it until it manifests again.
                  • #39
                    Well, if I can ever get enough money to put an alternator on it, I'll see if that helps!
                    • #40
                      Alternator is off and being rebuilt. Will be ready tomorrow. Looking forward to see how this thing runs!
                      • #41
                        Go the alt on last night. Car was dead this morning.....my new battery tested bad! Got that replaced and waiting to drive home to see how it runs!
                        • #42
                          Clean the terminals and the grounds to the chassis and the engine
                          • #43
                            Sounds like you have a short to ground. Its can be fairly easy to find,I would start by pulling the radio fuse if the Battery drains again. A cheap amp meter in series with the battery cable is the quickest way to find it. My E350 kept doing this and I kept blaming my kids for leaving the inside map lights on! Turned out it was the Rheostat in the dash dimmer switch. drool
                            • #44
                              Well I had been driving it with a new battery and bad alternator. Would that have made my battery test bad?
                              • #45
                                Did you get a printout of the test? Where any of the cells dry or really low on electrolyte?
