That is okay at the injector under those conditions. If you measure from battery ground to the connector you will get a reading probably a little less than battery but close.
Ok I'm baffled
Dale you nailed it. I initially did check all the fuses and before the engine fuse was blown. I guess through the process of checking and installing everything the engine fuse must have blown again. So I replaced it again and after two cranks she started and went to a slow idle.
Thanks Dale for your help
Now I just need to burn out the bad gas in the system up.
Thanks againLast edited by gunnerw; 08-30-2014, 08:14 PM.
Thread moved to the proper section
