So I jack up the front end to spin my front tires..
  • #31
    That shim is for that knuckle. New knuckle will require it own shim or have to be setup from scratch.
    Sent from my USCC-C6721 using Tapatalk
    • #32
      Don't tell me that. The shim goes on the hub and I know it its then pressed onto the knuckle. It seems that it wouldn't matter if the knuckle is different cuz the shim rides on the hub knot the knuckle. Please be wrong about this. I'll give ya a dollar.
      • #33
        So they took a torch and held it on the hub so long that it burned through a quarter inch of iron before buring through a quarter inch of iron?
        That or he took a torch to a knuckle with the hub already out and held it there for some reason until it burned through?
        If I understanding this correctly, was he high? I am not the most mechanically inclined but even I know when metal starts to drip I may be doing something wrong.
        06 Jeep Cherokee Overland
        95 Aspire (sold)
        • #34
          The latter. To the hub cuz he couldn't get the race out. I'll post a pic tomorrow.
          • #35
            Nope. The shims are specific for each hub. Because of casting differences. While the one you have may work. Good chance it won't. Have to measure it with a mic and make your own on a lathe.
            • #36
              And when the race is in there like that.....you take a chisel and crack the race and it comes out in pieces.
              • #37
                You owe Nitrofarm a dollar.
                There are 21 different shims to compensate for differences in the machined hub and bearing.
                They are still available from Mazda.
                Better to get another known good hub or one that needs rebuilt with the proper shim still intact.
                Have had many new bearings put in using the shim that came with the hub.
                Manual says you need to test with different shims till you reach the appropriate torque spec required to rotate the assembly.
                Clearly this is not always true.
                • #38
                  I still have the shim and hub that go with each other. What I want to know is why I can't put a different knuckle on this same hub. Why would it matter? The shim does not ride on the knuckle.
                  • #39
                    You can send me all your parts plus 4 bearings and 4 seals. Then I'll charge $80 labor + @ $25 for shipping. I have all spacers already. I don't need the money just do it to help out. Its best to have someone work on these that is familiar. Can't believe someone couldn't punch out a race.
                    • #40
                      The hub that spins isn't what your shimming. Its the space in between the bearings. Your preloading them. You don't even use the hub when doing the setups. Just the bearings and knuckle and spacer.
                      • #41
                        I wish I could do that nitro but the guy at performance told me the knuckle is ruined. It is so beat up and outta round. He said if I try and put another bearing it there it will just get chewed up again. I'll try and get a picture of it so you can see it yourself.
                        • #42
                          I have knuckles
                          • #43
                            my fronts make a little noise too when spun but I think it is brake drag. Does one hub get hot when you drive it?
                            • #44
                              I really appreciate that offer. I am checking into a possible junk yard set for $60. If that falls through I will get back with you.
                              • #45
                                messed up knuckle
                                Here be some photos.... Plus a pic of the world famous preload shim..its a number 10.
