I have a Festiva that is consuming oil & so does my friend, with a Festiva. On mine, I have done 5 different MMO & Sea Foam treatments on it with no results except for 2 weeks it does not consume oil then the oil turns black and it consumes 1-2 quarts every 150 to 200 miles with no signs of oil burning smoke or leaking. I have good compression, but I will have to double check again.
I am assuming it is bad rings instead of them sticking, but could it be something else? I have little knowledge on these engines. Please help.
My friends is doing the same thing. He has not checked the compression even though the engine seems to have good compression.
I have posted this problem on another thread with a totally different title, but I thought I would start this again with just this subject matter.
Thanks in advance.
Thanks in advance.
