Oil consumption on these Festiva's..
  • Oil consumption on these Festiva's..
    I have a Festiva that is consuming oil & so does my friend, with a Festiva. On mine, I have done 5 different MMO & Sea Foam treatments on it with no results except for 2 weeks it does not consume oil then the oil turns black and it consumes 1-2 quarts every 150 to 200 miles with no signs of oil burning smoke or leaking. I have good compression, but I will have to double check again.
    I am assuming it is bad rings instead of them sticking, but could it be something else? I have little knowledge on these engines. Please help.
    My friends is doing the same thing. He has not checked the compression even though the engine seems to have good compression.
    I have posted this problem on another thread with a totally different title, but I thought I would start this again with just this subject matter.
    Thanks in advance.
    1993 Ford Festiva L blue 170,000 miles
    1990 Ford Festiva L Plus white 190,000 Auto, currently waiting to have another engine put in.
    1995 Ford F150 XLT black 203,000 miles
    2002 Honda CRV silver 180,000 miles
    2003 Toyota Rav4 Sport black 94,000 miles
    2008 Sym Rv250 dark grey 30,000 miles. My scooter.
    1989 Ford Festiva LX black 233,000 miles. Sold to my better half's son.
    Mike
    Im assuming you checked for blown head gasket? Depending where it blows you won't see signs on the exterior of the motor but will see brownish gum in your rad for example
      if your oil is turning black too quickly, then it could be that the engine is running too rich... the oil is getting diluted with gas.
        Head gasket is fine.
        Mike
          How do I adjust that?
          Mike
            Bad rings will also allow combustion gases into the oil causing black oil. Sucks the oil up on the intake stroke and blows intake gases down past the piston on the compression stroke.
            Rick
            1993 Ford Festiva
            2000 Ford E350
              they make a ring treatment, its really thick like honey , that and going up to 10w40 helped mine alot
              He said a bad word :nono:
              1990 Festiva
              1987 F-250 diesel-powered
              1984 Ironhead Chopper
              1999 Ducati Monster
                Is it carb or EFI? Also, Eaglefreek is right, that could be another failure.
                Have you checked the PCV? Do you have oil in the intake? Are you 100% sure that you don't have smoke of any kind? i once had some valve steam seals gone bad and the car only smoked a little at start up, that could be also....
                  Unhook your little 90 deg hose from the air filter side on top of the valve cover. Temporarily tape off or cap the nipple on the air filter to keep dirt and air out. Leave the hose over the top of the valve cover open. Drive the car a bit then look and see if any oil is on top of the valve cover.
                  This helps to pin whether the oil is coming down the intake or is a problem of rings or valves.
                    That is my thinking, someone else had told me that.
                    EFI.
                    There is oil in the intake. It drips out a little at the lowest point of the intake hose. Does that mean bad rings?
                    Mike
                      EFI.
                      It could mean rings are worn, bore is worn, or piston worn, or all of it worn. But because this is a indirect symptom the valve cover would have to be pulled and the oil baffles under the tin plate inside the valve cover cleaned. If oil puddles in there then a good engine will push oil into the intake. Also the pcv may be sucking but the hose should be pulled and the nipple cleaned with a small round brush and carb cleaner from a spray can. You have compression good enough for the car to start and idle smoothly. You have cleaned the rings with cleaner extra good. Make sure the baffles and the pcv vacuum hose and port is clean too.
                      If you pull the 90 hose clear off the valve cover and start the car it is normal to have a lot of puffing going on. If you snap the throttle and a stream of oil misty air shoots up and deflects off the bottom of the hood, that is bad ring seal.
                        Say no more, rebuild or swap time!!! You may try urban legends additives, but in the long run they wont cure the sickness.. I think there has been some people here that had done budget rebuilds; give them a search...
                          I think I'm going to remove the valve cover, clean everything underneath & clean everything else you said. My feeling is bad rings though.
                          My long term plan is when I have a B6 put in Silver Streak, the engine I get out of that I will put on my engine stand, overhaul it & put it in the Festy that's consuming oil (Blue), take that engine and overhaul it & maybe put it in my DD Festy (shadow) or maybe get another Festy to put it in.
                          Mike
                            Update on the Blue Festy:
                            Well, I took it to my mechanic last week. G-dine's son drives the Festy back and forth to college and she was able to get a service agency to fix the Festy for up to $1000.
                            Anyway, He says the pistons have 3 rings. the lowest rings are the oil rings which we're all stuck and on one of the pistons the 2nd ring was stuck. He told me there was no way I was going to un-stick the oil rings with the treatment, they we're corroded bad. He also said the bearings are worn.
                            He is replacing the rings, bearings, & will hone out the piston holes.
                            The engine will run like new when it's done in a week. I'm glad because it ran great even with the problems it had.
                            Thanks everyone for your advices.
                            Mike
                              Wow, yes treatment will not free corrosion, only petroleum gunk and carbon. Biofuel blend or do you get humidity ?
